Activity › Forums › Apple Final Cut Pro Legacy › Color shifts in timeline. What the????
  • Color shifts in timeline. What the????
    Posted by Mark Chadwick on March 3, 2006 at 11:41 pm
    Have a question for everyone. I have loaded in an interview and when I hit stop the image gets brighter. When I hit play the image turns back darker. What is going on? I’ve taken off the wireframe and title safe option so that isn’t it.
    Any help would be great. thanks
    G5 dual 2gig
    FCP 5.0.4
    xserve tower
    Erik Lindahl replied 20 years, 6 months ago 8 Members · 11 Replies
  • 11 Replies
  • Tom Wolsky
    March 4, 2006 at 1:14 am
    Are looking at the output on a video monitor?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Mark Chadwick
    March 4, 2006 at 1:17 am
    No. But why the heck does it do that? Its a pain in the a** and if you want to color correct its a bigger pain.
    Avid here I come.
    thanks
    mark
  • Tom Wolsky
    March 4, 2006 at 1:29 am
    Bibi.
    All the best,
    Tom
  • Arnie Schlissel
    March 4, 2006 at 1:30 am
    Because you really shouldn’t try to color correct without a good quality video monitor that can be calibrated to color bars with a ‘blue only’ or ‘blue check’ feature. Computer monitors don’t display color in the same way that video monitors do. Also, the canvas output in FCP isn’t designed for any kind of critical viewing. Please consult your manual to see how to hook up a video monitor & speakers.
    Arnie
    https://www.arniepix.com
  • Shane Ross
    March 4, 2006 at 1:58 am
    If you need to color correct, as Arnie said, you need a high quality Production Monitor. Even on an Avid.
    YOu cannot color correct on ANY system riliably without one.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Michael Horton
    March 4, 2006 at 3:21 am
    Tom
    What’s Bibi mean?
    Michael Horton
    lafcpug
    https://www.lafcpug.org
  • Andy Mees
    March 4, 2006 at 3:06 pm
    its not titlesafe and wireframe overlays that tend to cause this, its usually the range check overlays.
    do you have the range check overlays turned on? (Ctrl-Z to toggle on/off)
  • Andy Mees
    March 4, 2006 at 3:13 pm
    Hey Guys
    No argument with your advice but its not the issue at hand.
    the particular bug being described is visible both on the Canvas and any external monitor … its not particulatly apparent when working with DV varients but is markedly more visible when working with uncompressed footage.
    put some uncompressed clips on an uncompressed timeline then turn on range check and see for yourselves
    bizarre but true
    Andy
  • Arnie Schlissel
    March 4, 2006 at 5:12 pm
    [Michael Horton] “What’s Bibi mean?”
    My guess is “bye-bye”.
    Arnie
  • Mactrix
    March 6, 2006 at 6:15 pm
    Hi Mark,
    this is absolutely normal. Check the system settings in Final Cut Pro.
    You can find there a gamma correction. It’s not possible to turn this
    off but what it does is to simulate the video gamma of your video
    monitor at the canvas video on your computer monitor. If you’re
    working in 10-bit the shift should be stronger than with 8-bit.
    Hope this helps …
