Activity Forums Adobe Premiere Pro Color shift when exporting through Media Encoder
  • Color shift when exporting through Media Encoder
    Posted by Timothée Ferreol on February 4, 2017 at 6:12 am
    If I render from Premiere the color looks as I color graded them but whenever I queue it to Adobe Media Encoder, there is an horrible color cast, do you know a way to fix that please ? I suppose it is a color space problem, but have no idea how to fix it
    Premiere : (OK)
    Adobe Media Encoder (not OK):
    ___________________________________________
    If you want to check out my work =) : https://vimeo.com/timof
    Jeff Johnson replied 7 years, 11 months ago 2 Members · 2 Replies
  • Timothée Ferreol
    February 4, 2017 at 6:25 am
    Okay I found out the solution :
    “Copy the LUTs from PP app “package” Contents/Lumetri/LUT/Technical Folder, and paste everything to AME Contents/Lumetri/LUT/Technical Folder.”
    worked out 🙂
  • Jeff Johnson
    October 4, 2018 at 7:18 pm
    Thank you so much! This was very very helpful.
