Activity Forums VEGAS Pro Color shift on import
  • Color shift on import
    Posted by Bruce Gaber on January 19, 2011 at 4:40 pm
    I work exclusively with still images and have just begun to explore them within VP-10. And as a newbie, of course I have a problem.
    My very carefully color balanced images import into VP with a distinct greenish cast, both as thumbnails in the the media viewer and as images in the viewer and final render. Yes, I can correct this to some extent with Sony color balance, etc., but this is a very tedious and rather imperfect way to correct images that are already properly balanced.
    The images have been saved as either PSD or PNG (no difference) using the ProPhoto RGB color space (moving to a smaller space might mute the colors, but shouldn’t shift them radically). I am running VP-10 under virtualization (Parallels) on a iMac core i7 with 8Gb RAM.
    Please excuse me if this issue has already been addressed, but I did not find it in a search of previous posts.
    Your help and suggestions very much welcomed–and needed!
    Thank you
    Bruce
    Theo Van laar replied 15 years, 7 months ago 2 Members · 1 Reply
  • Theo Van laar
    January 22, 2011 at 10:04 am
    Why don’t you use in photoshop the same colorspace as you are goping to use in Vegas? That should prevent colorshifting.
    Theo
