Activity › Forums › Apple Final Cut Pro Legacy › Color scopes
Color scopes
Posted by Amir Abed on May 25, 2009 at 1:28 amI was wondering how accurate the waveform and vector scopes are within Final Cut. Also I read that Final Cut’s scope only give you a reading on whats within the action safe. Is this true? Thanks.
Amir Abed replied 17 years, 3 months ago 3 Members · 4 Replies -
Shane Ross
May 25, 2009 at 2:56 am[Amir Abed] “I was wondering how accurate the waveform and vector scopes are within Final Cut.”
Pretty good. I use them still. I just make sure that I am very visibly below 100 IRE, just to be sure. Can’t afford HD hardward scopes just yet. Awaiting the ones from Decklink.
[Amir Abed] “Also I read that Final Cut’s scope only give you a reading on whats within the action safe. Is this true?”
Nope…pure poppycock. In FCP 3 and 4.5…that might be closer to the truth, but not anymore.
Shane
Read my blog, Little Frog in High Def -
Amir Abed
May 25, 2009 at 9:51 amThanks Shane
“Can’t afford HD hardward scopes just yet. Awaiting the ones from Decklink.”
Is that because an external scope is more accurate? But FCP scopes can get the job done.
Walter Biscardi
May 25, 2009 at 11:38 amHardware, dedicated scopes are always the absolute most accurate you can buy.
That being said, we use only FCP and Color scopes here and have been since 2001. Color’s scopes are especially accurate, moreso that FCP’s, but FCP’s scopes get the job done. We’ve delivered well over 100 HD broadcast masters and 200 SD masters using only the software scopes and not a single QC rejection due to levels.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
