Activity Forums Avid Media Composer Color Quality in avid
  • Color Quality in avid
    Posted by Asif` Rasheed on July 1, 2008 at 2:41 am
    I bought a new system the configration is: Intel Core 2 quad, cpu q9300, 4 Gb of Ram, BFG Nvidia GE force 8800 GT OC video card. I have avid express pro 5.6. The problem is , when i play imported video no matter on timeline or composer window it losses quality and same quality i get in in exported video it shows like VHS quality. can someone help me detirmin what happened here.
    Regards
    Asif
    Asif` Rasheed replied 18 years, 2 months ago 4 Members · 4 Replies
  • Bouke Vahl
    July 1, 2008 at 3:13 pm
    What kind of files are you importing?
    Did you check the RGB vs 601 options?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Brian Thomas
    July 1, 2008 at 3:53 pm
    2 things to double check
    1) the resolution you are importing at…if it is low such as 15:1 or such that will do it…I suggest 2:1 or higher
    2) on your timeline, there is a green button on the lower left that sets the quality of the resolution in your timeline in the lower left…make sure it is green and not half yellow/half green or full yellow
    Avid Editor
    New York City
  • Grinner Hester
    July 4, 2008 at 2:35 pm
    when avid downgraded their line of products, they added a half and low rez button to try to make up for the clunky RAM play. I bet if you click it to green you will see a better image.
  • Asif` Rasheed
    July 7, 2008 at 2:43 pm
    thank you for help problem solved
