Activity Forums Compression Techniques Color problems going from PC to Mac
  • Color problems going from PC to Mac
    Posted by Nicholas Montgomery on December 7, 2009 at 11:42 pm
    Hey all
    I’ve got a video (~10 min., 60GB unc mov) to deliver to be viewed on a Mac in a week or so. It was edited on Vegas, brought over as Unc mov to Mac, to be converted to a more suitable mov (since the editor doesn’t know / isn’t capable of delivering it in the right format).
    I tossed it into Compressor and used H.264…no luck. Came out with choppy playback.
    Gave ProRes a try, even though I was told never deliver with ProRes (although I’ve never really understood, as some clients ask specifically for this). Played well, and at 7GB, not bad. Only the contrast is way off, it’s much brighter. Poses a problem as the image was darkened to cover up some flaws.
    I never realized the picture difference with ProRes. Is there a better mov codec that I should use for delivery? Just needs to be transported easily (if it can fit on a DL DVD, that would be ideal).
    Cinematographer / Editor
    Synn Studios Inc.
    Tanel Viksi replied 16 years, 8 months ago 4 Members · 4 Replies
  • Daniel Low
    December 8, 2009 at 8:25 am
    What Gamma settings are you using?
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
  • Nicholas Montgomery
    December 8, 2009 at 8:51 pm
    I hadn’t touched the gamma settings. Left them as is.
    Synn Studios Inc.
  • Kristofar Rieleef
    December 11, 2009 at 10:12 pm
    Have you tried exporting to an uncompressed .avi out of Vegas? This should work in the Mac. You can also render the file out of Final Cut instead of using Compressor. Does the video play in the Final Cut timeline with the noticeable changes you’re talking about? If those are noticed, you may want to tweak it in Final Cut and then export that way, so you’ll get what you’re wanting for picture quality. You could probably achieve the right compression staying on the PC. Using Quicktime Pro to render you’re file.
  • Tanel Viksi
    December 19, 2009 at 8:59 am
