Activity Forums Adobe After Effects Color Problem Exporting .SWF
  • Color Problem Exporting .SWF
    Posted by Ernest Ng on December 5, 2008 at 4:31 am
    Hello, ive made a particle effect using Particle Illusion, and then i exported it using .TGA image sequence with alpha channel so i have transparency background. Then i import image sequence in AE CS3, then export it as .SWF, then Import SWF in flash…but when i play the swf files the color changed, doesnt show like the original one.
    Any solution to this ?
    Ernest Ng replied 17 years, 9 months ago 2 Members · 2 Replies
  • Jason Milligan
    December 6, 2008 at 2:01 am
    Is there a reason you are creating your swf in AE instead of importing the Targas directly into Flash?
  • Ernest Ng
    December 6, 2008 at 4:31 am
    yeah thanks, just realized i could take the image sequence direct into flash…lol…im so silly
