Activity › Forums › Adobe After Effects › Color Picker
  • W M d
    June 18, 2005 at 7:28 pm
    Had this problem once, didn’t know how it happened, or how I stumbled upon the solution…
    In the Info window, click in the RGBA area. Each time you click, it will change the way the range of values is evaluated and displayed (0.000 to 1.000, 0 to 100%, 0 to 255, etc ). When you get to setting that you prefer to work with, just leave it alone and when you go back to the color picker, RGB values should display as desired.
  • Aharon Rabinowitz
    June 19, 2005 at 2:17 am
    I didn’t know that. Cool.
    You can also just click the black > Arrow on the upper right corner of the info pallate which gives you a pulldown with all of the different options.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Joshua Glaudin
    June 21, 2005 at 10:20 pm
    I tryed it and it worked
    thanks
