Activity Forums Adobe Premiere Pro Color out put differs from color in sequence.
  • Color out put differs from color in sequence.
    Posted by James Barry on November 6, 2015 at 3:31 pm
    So I’m running into an issue where my export’s color is very very different from the color I see in my PP sequence.
    I’m using the Vimeo 1080 preset to export from a UHD sequence, not sure if that info is helpful.
    Specifically it looks like my footage is over exposed in my export, by like a full stop. I have not tried to stop down my sequence yet, I thought I would preemptively ask here first.
    Thanks.
    James Barry replied 10 years, 9 months ago 3 Members · 5 Replies
  • Jon Doughtie
    November 6, 2015 at 5:05 pm
    What screen(s) are you using to view your timeline and your export? If on the same monitor, what application are you using to view the export?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • James Barry
    November 6, 2015 at 5:44 pm
    Both timeline and export were viewed on a 27″ iMac with retina 5k. I viewed the export in Quicktime and VLC.
  • Steve Brame
    November 6, 2015 at 5:46 pm
    Interesting. I’ve just discovered the same problem. I’ve got Ultra-keyed footage against a still background photo, with a Lumetri effect on the foreground. On export to H.264 and Avid MXF, it looks as if the Lumetri grade is being ignored. I also tried Matrox AVI, and that works much better. The difference in the exported image and that of it in the Program monitor is stark.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • James Barry
    November 6, 2015 at 5:50 pm
    Yeah it’s very odd. You can see how different the export is from the timeline
  • James Barry
    November 6, 2015 at 5:51 pm
