Activity › Forums › Avid Media Composer › color off when editing with AVID
  • color off when editing with AVID
    Posted by Flip Minott on February 20, 2008 at 6:23 pm
    I shot a whole feature with my Varicam H27 using a 27in monitor to make sure everything look right. I edited it with Final Cut Pro. I didn’t have any probelms with color footage.
    I am having someone else edit some footage and he is using Avid. He says the footage is look green,flat and less color saturation. It is the same setup as before except using Avid instead of Final Cut Pro. I know Final Cut was made to work with the VaricamH27. Why is this happening color probelm happening with AVID and what can i do to fix it, so we don’t have to do so much color corection?
    Oliver Peters replied 18 years, 7 months ago 3 Members · 3 Replies
  • Grinner Hester
    February 20, 2008 at 8:53 pm
    you cannot go by what system it’s on. Your scopes and a properly calibrated NTSC monitor/your eyes are your tools for this.
    all decks are gonna vary playback a bit… hence the color bars at the front of every master.
  • Flip Minott
    February 20, 2008 at 11:46 pm
    I shot a whole feature with my Varicam H27 using a 26in monitor to make sure everything look right. I edited it with Final Cut Pro. I didn’t have any problems with color footage.
    I am now having someone else edit some footage and he is using Avid. He says the footage is looking green, flat and has less color saturation. It is the same setup as before except using Avid instead of Final Cut Pro. I know Final Cut was made to work with the VaricamH27. Why is this color problem happening with AVID. What can i do to fix it, so we don’t have to do color correction?
  • Oliver Peters
    February 21, 2008 at 12:34 am
    Flip,
    I just took a look at the feature you mentioned. It looks nice, but contact me offlist and I think I can help explain.
    Sincerely,
    Oliver
    oliverpeters (at) oliverpeters (dot) com
