Activity Forums Boris FX Color-matching costant variations between frames
  • Color-matching costant variations between frames
    Posted by Don Hutcheson on November 6, 2011 at 11:11 pm
    I have a bad HD tape that created constant variations in color hue and intensity. The footage will need color matching about every three seconds (for a 60-minute interview!). Can I isolate a color-accurate frame in Boris Color Match and tell it to apply that to the rest of the timeline?
    Thank you,
    Don
    Hutch
    Don Hutcheson replied 14 years, 10 months ago 2 Members · 2 Replies
  • Peter Mcauley
    November 7, 2011 at 1:43 pm
    Hi Don,
    Although the BCC Color Match filter excels at performing 3 point color matching between clip pairs, the filter does not constantly read and analyze clip color or luma changes across time so if the color is changing every 3 seconds or so, you’ll need to adjust the filter manually using keyframes to compensate for this change. So while it is indeed possible to achieve the result that you have in mind for this piece with this filter, it’s a little more than a drag and drop solution.
    In BCC 8 we have a brand new filter that will automatically compensate for luma shifts, which will probably handle the job nicely for you. It’s called BCC Flicker Fixer, and you can instruct the filter to automatically compensate for fast, or in this instance, slow flicker or luma shifts. If you would like me to try a short segment of the clip I’d be happy to do that for you – just get in touch with me off list and we can take it from there. You can reach me at peterm@borisfx.com.
    Cheers,
    Peter.
  • Don Hutcheson
    November 7, 2011 at 4:17 pm
    Very kind, Peter. I will get a clip to you.
    Thank you,
    Hutch
    Hutch
