Activity Forums Adobe After Effects color match help!!!
  • color match help!!!
    Posted by Huacuja on July 4, 2006 at 8:41 pm
    Hi people.
    Well, i have a problem, because, i have to deliver some quicktimes right now, and my problem is that , when i rendered my animation, i compare my final colors, and doesnt mach with my original file, from photoshop.
    I have seen, that the color settings in photoshop is in sRGB iec61966-2.1 And my after effects was in -none- … So, i change it in after, and my final quicktime, doesnt change. And in my composition i do saw that change!!! But in my mov, dont
    What happen? This is for broadcast, ….
    PLEASE HELP!
    deachete@hotmail.com
    Michiel replied 20 years, 2 months ago 2 Members · 1 Reply
  • Michiel
    July 5, 2006 at 8:16 am
    AFAIK After Effects doesn’t use color profiles like photoshop does (they are meant for print). Try disabling the color profiling in photoshop. When you throw away the color profile for your document in photoshop, you might see a color shift. If it’s very noticeable you can use photoshop’s built in tools to get it back to as close to the original colors as possible, then import it into after effects and you it should look the same.
