Activity › Forums › Apple Final Cut Pro › Color Match FCP X Application
  • Color Match FCP X Application
    Posted by Josh Madsen on August 31, 2011 at 4:29 pm
    I’m trying to figure out how to use the color match application in FCP X. I’m able to get as far as using the skimmer, seeing the two clips, etc. However it won’t allow me to click and select. In other words I can see everything, but the apply button appeared to be disabled.
    I’m sure I’m missing something really simple, so any help would be appreciated.
    Thanks.
    Mark Morache replied 15 years ago 2 Members · 1 Reply
  • Mark Morache
    September 2, 2011 at 6:45 am
    This works for me:
    Select the clip you want to change
    Click “color match” in the video properties bin to activate the match color function
    Skim to the frame of the shot you want to match your clip to.
    Click the frame in the clip, and the “apply match” button should activate.
    Press the “apply match” button and it takes effect.
    Are you clicking on the frame of the clip you want to match?
    I’m calling it FCX. They took the “pro” out, so I will too.
    I’ll reconsider after the first upgrade.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    blogging at https://fcpx.wordpress.com
