Activity › Forums › DaVinci Resolve › Color Management for VFX pipelines
  • Color Management for VFX pipelines
    Posted by Jim Bachalo on February 16, 2023 at 7:42 pm
    For linear exrs rendered from Unreal, what is the best color management workflow?
    I have been using William Faucher’s non-ACEs linear exr workflow
    https://youtu.be/Bo3BvhGdaUo
    In Unreal disable tone curve before render and then
    Color science > ACEScct
    ACES Input Transform > none
    ACES Output Transform > Rec.709
    And then right clicking clips > ACES Input Transform > Color Space Conversion > sRGB Linear
    Would there be any advantage or use for CST nodes instead?
    ie https://youtu.be/CtSBVKmHkjU
    Riccardo Luppi replied 3 years, 6 months ago 2 Members · 1 Reply
  • Riccardo Luppi
    March 4, 2023 at 8:31 am
    Hey Jim,
    Personally, I tend to use the CSTs when grading because, as a colourist, I like to have full control of the transform functions. That said, it requires a bit more understanding of the said transform functions, as well as a bit more time to set them up correctly. if you are interested in knowing more about the CST, let me know!
    one thing that I noticed in Faucher’s process is that he is setting the output to Rec709. You should set it to Rec709 Gamma 2.4 instead.
    Finally, I would probably recommend you use the ACES workflow, as that allows for more colour fidelity when moving from one software to the other. This last part, though, is not mandatory.
