Activity Forums Adobe After Effects Color management: Flow chart from Greenscreen to Youtube
  • Color management: Flow chart from Greenscreen to Youtube
    Posted by Greg Sage on February 20, 2014 at 6:01 pm
    I’ve been asking about bit depth, but I’m beginning to see just how much bigger the real question is, and I’m nearly dizzy after a couple days of reading on color management, so let’s see if I can get things narrowed down:
    Using a hacked GH2 to do greenscreen footage, then using After effects to combine with C4D renders, jpg backgrounds, GH2 footage, and a dizzying array of effects and layers to make music videos which will be on my site and youtube.
    Looking for basic formula for color management. Here’s what I think I’ve learned so far:
    GH2 is 8 bit color.
    Internal color space for AE: 16 bit / sRGB / Linearize working space / compensate for scene referred profiles.
    Watch out for 8 bit effects.
    Calibrate monitor (colormunki on order).
    Right so far?
    And I’ve got the YT 1080/29.97 preset for Media Encoder, though not sure what my exact settings should be coming out of AE.
    Greg Sage replied 12 years, 6 months ago 49,409 Members · 4 Replies
  • Greg Sage
    February 21, 2014 at 1:50 pm
    Well, that’s really more what I’m talking about. I mess with the footage quite a bit, and am more concerned with it looking good than necessarily looking “correct.”
    Doing basic white balance, and shooting with supposedly flat settings on camera, but no MacBeth chart or anything.
    Really just trying to work out the technical settings going from camera to Youtube. Camera is what it is. Not ideal, and not 4:2:2, but GH2 is what I could afford.
    Specifically, I’m wondering about setting from AE on out… so project settings, render settings, compression settings. Since ultimately using Media Encoder for the last step with the built in YT preset, if I get the first two right, that should take care of itself.
    So, am I right so far in that I should be doing:
    PROJECT SETTINGS
    ________________
    16 bit
    sRGB
    Linearize color space
    Adjust for embedded
    RENDER SETTINGS
    _______________
    MEDIA ENCODER SETTINGS
    ______________________
    YT 1920×1080, 8Mbps preset
  • Greg Sage
    February 22, 2014 at 2:45 pm
    I’ll answer to the best of my ability. If I need to be looking at something else, just let me know.
    The files coming off the GH2 are .MTS files which are 1080p AVCHD.
    So… is that an AVCHD file in a .MTS wrapper?
    Can’t control the file type off the camera, but from that point, I can choose everything else. If it needs to be transcoded, re-wrapped, or whatever, I can choose the settings.
    So… convert to ProRes422 and .mov before editing? mp2? I’ve been quite unhappy with the keys I’ve gotten despite good lighting and the use if Intra-Frame 1080p setting on camera… not sure if my choice of conversion formats could have affected that.
    I’m also combining that footage with jpg files, and png files half of which I create, and half of which I find. Then combining that with c4d output. Again, I can choose any output settings I want for the C4d stuff since I’m creating it.
    Really, the only limitation I have in there anywhere is how the files come off the camera… which is avchd files in a .mts wrapper. Everything else can flow however I set it up.
    Does that help, or do I need to be looking at some other aspect?
  • Greg Sage
    February 25, 2014 at 3:31 am
    ok
    so just 16 bit, no color management?
    Is there something in particular I need to be aware of in process of transcoding? Settings available somewhere? Preferred program?
  • Greg Sage
    February 25, 2014 at 6:32 pm
    Sorry, I think I’ve mentioned too many things confusing the issue a bit. I have no intention of using FCP.
    I’m using the Adobe suite, and with so many layers and effects going constantly, it’s done almost entirely in After Effects.
    This should be a very easy thing to figure out. I only have one item I don’t control output details for… the GH2 footage which is AVCHD .mts files.
    Everything else like C4d footage, I can specify any output I like.
    Videos are being done in AE. I only mention ProRes because other people have suggested I use those settings.
    This should be a very straight forward issue as there are very few variables. It’s just the same workflow over and over:
    Flow = GH2 to After Effects To Media Encoder to Youtube with whatever the optimal steps are in between to get best use out of the greenscreen footage, and best possible viewer experience on YT.
    I’m not saying I should use Pro Res. I’m asking what I should be using.
