Color Management Exercise
Hello,
i am working with AE for years but still can’t figure out color management. For example:
I export prores footage out of FCP and import in AE, there it is assigned a HDTV (rec 709) profile.
I want to export this file with alpha (applied a mask) to QT animation w alpha.
If I do this without color management on, the rendered file is much brighter when imported back into FCP. Allthough imported back into AE it looks the same as the prores file.
I get the same result if I use the HDTV (rec 709) profile for my color management.
I get much better results if I use the Adobe RGB profile, but it still not 100% accurate.
How do I 100% accurate results? What settings do i have to use?
Greetings,
Bart Winckers
