Activity › Forums › Adobe After Effects › Color keying?
  • Color keying?
    Posted by Calder on April 14, 2005 at 2:16 pm
    What is the best plugin for keying (all plugins out there not the standard ones)
    So far keylight and color range with the addition of a matte choker works the best.
    But it isn’t exactly want i need, it has that, “well he was definently green screened” look
    I’m sure some company has released one that will do the job?
    Chris Smith replied 21 years, 5 months ago 2 Members · 1 Reply
  • Chris Smith
    April 14, 2005 at 2:31 pm
    If you can’t do it with Keylight then the shot wasn’t lit right, the parameters aren’t set right or the key is fine and the comp needs tweaking. Keylight was designed by CFC and used in many Movies and TV commercials. It is one of the best keyers made. It’s up there with Primatte and Ultimatte. I would predict that even if you used Primatte, the end comp would look similar to how it is with Keylight. Do you have a still or QT link to the shot you are working on?
    Chris Smith
    https://www.sugarfilmproduction.com
