Activity › Forums › Adobe After Effects › Color Keying Problem
  • Color Keying Problem
    Posted by Mostafa Talebi on September 14, 2011 at 8:24 pm
    hello
    I have done up to a some level for keying this movie. but I have problem to remove tracking marks and to remove the additive annoying color made upon the character marginal area.
    shown in picture below:
    Ben G unguren replied 15 years ago 3 Members · 4 Replies
  • Stefan Hinze
    September 14, 2011 at 9:27 pm
    hey,
    i think its a problem of the codec.
    how ever, try this to solve the problem:
    use the AlphaMask of the key and aply it to the duplicated footage (on the dulicate you dont need a keyer!)
    dublicate the clip
    keep the clips at the same time // synced
    remove the key from the lower copy
    set the lower clip to get the alpha from the upper one
    if it dosn´t work – precompose the upper one
    hope this helps
    stefan
  • Ben G unguren
    September 14, 2011 at 9:35 pm
    I concur with Stefan’s suggestion. One addition: go ahead and use the key on the bottom layer, but tell it not to use the alpha. If you’re using Keylight, there is a view setting called “Color Corrected Footage” — this allows Keylight to remove all the spill, etc, but doesn’t actually do any cutting. I suggest you use the simplest (that is, default-est) settings possible for this lower layer. The color problems you’re experiencing are probably from the keyer trying to remove spill while simultaneously keying a substantial range of the image….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mostafa Talebi
    September 14, 2011 at 10:09 pm
    Hey man Thank you
    your solution got to work, but it continues to have a transparent green bg instead of a full transparent bg.
    I’m using Primatte Keyer plugin.
    In fact with key light plugin I go completely O.K with no cutting-in error and everything looks fine.
  • Ben G unguren
    September 15, 2011 at 1:04 am
    Sounds like keylight is the solution to use for this particular shot! Glad you got it to work.
    Ben Unguren
