Activity Forums Adobe After Effects color isolation
  • Ryan Hill
    March 10, 2006 at 2:47 pm
    Leave Color
  • Mark
    March 10, 2006 at 2:57 pm
    For more flexibility I use change color…..
    Use 3 copies of same footage. Apply change color to top layer and select the color. Next in the filter select color matte from the drop down. Set this to be a track matte to layer two using luminance.
    Adjust track 3 as you would like. I do this, as usually I don’t want to just remove color from the background..I may want to use a tritone filter along with blurs and levels to mess with the image.
    Hope this helps
    Mark
