Activity Forums Adobe After Effects Color handling in AE
  • Color handling in AE
    Posted by Jakob Mårtensson on November 9, 2009 at 6:11 am
    What is the correct way to import and export footage in to AE to get the most correct output ?
    I often use AE to clean up footage and remove microphones and such. Just the other day I imported some DVCPRO HD 720p material removed some disturbing pixels in the corner and exported the clip with the exact same settings. When I got the clip back to FCP it was around 10% brighter than the original clip.
    What is the best way to avoid this ? What did I miss ?
    Todd Kopriva replied 16 years, 10 months ago 2 Members · 1 Reply
  • Todd Kopriva
    November 9, 2009 at 9:23 pm
    It’s possible that you’re running into known problems with QuickTime’s handling of gamma.
    Here’s a technical support document on an issue that may be related to what you’re seeing.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
