Color grains on damaged frame
Hi, I’ve been working on an AE comp but recently got these red, green and blue grains on a couple of frames of my MP4 clip.
The file doesn’t seem to have any problems outside After Effects, no damaged frames as far as I can see. I have several masked layers above this clip (other layers revealing this original track), an animated camera and an adjustment layer.Any ideas on how to fix this?
(Also, I’m using this comp into another one, tracked and keyed (using keylight) on a green screen, but I don’t think that is causing this issue since I can see the damaged frames on the first comp.)
