Activity Forums Adobe Premiere Pro Color grading multicam.
  • Oliver Peters
    January 16, 2015 at 1:22 pm
    One approach is to use SpeedGrade for your color correction. You would collapse the mcam sequence when you are done cutting. Then Direct Link to SpeedGrade. In SG, use master clip which will apply the same correction to all instances of the clip in the timeline. You can still use a clip grade to tweak each shot. Then send back to PPro. This requires CC2014 versions of all.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Ispaxan Nixteridakis
    January 16, 2015 at 1:38 pm
    Thanks Oliver,
    I have never worked with Speed Grade before but i think i should give this workflow a chance.
