color grading for stock
i am supply footage for stock use. the stock house allows me to color grade the stuff i send them. i would prefer to do this as the footage is wildlife, so a bit of help makes it stand out when the client’s looking at many clips.
this is my proposed workflow:
1. panny varicam 720p 422 footage brought into final cut pro native.
2. i grade each clip using one or more of the following filters: color corrector, color corrector 3way, channel mixer, gamma correction.
3. i set the sequence settings to uncompressed 10bit 4:2:2, and use the rendered files.
my questions are:
how much would the client then be able to grade this finished footage, say for example if the client wants a look or a style? using 4:2:2 how much color am i really removing, if i am just white balancing and removing color casts during my grades.
should i set the blacks and the whites to be within 0-100 on the parade scope of fcp, or can i assume that so long as the levels are with in the parade’s scope, i.e so setting the highlights just over the ‘white’ 110 line and not showing clipping then they will still be fine to re-grade?
many thanks.
