Activity Forums Adobe Premiere Pro Color grade in Pr preview doesn’t nearly match my exported H.264 file
  • Color grade in Pr preview doesn’t nearly match my exported H.264 file
    Posted by Jeff Arthur on September 11, 2018 at 8:48 pm
    I have been using Premiere for a long time but recently started using LUTS and getting into grading. Has anyone run into the problem where the grade you see in the preview is completely different than the exported file??? I tried exporting using H.264 and as a Quicktime file but both are coming out very flat- almost like the LUT isn’t taking. If someone could help or post a link where this has been discussed before I would appreciate it. Screenshots are below of the difference.
    Example1:
    In Pr
    H.264 Export
    Example2:
    In Pr
    H.264 Export
    http://www.silencefilms.com
    Jeff Arthur replied 8 years ago 4 Members · 6 Replies
  • Shane Ross
    September 11, 2018 at 9:39 pm
    How are you viewing that exported file? IN QT? It’s highly inaccurate…wrong, busted. Use VLC player, see what it shows.
    Shane
    Little Frog Post
  • Jeff Arthur
    September 12, 2018 at 12:04 am
    [Shane Ross] “How are you viewing that exported file? IN QT? It’s highly inaccurate…wrong, busted. Use VLC player, see what it shows.”
    Thanks for responding. I only use VLC for viewing media. I wonder if there are some settings for making sure the LUT is applied that I am missing? This seems to be a widespread issue.
  • Chris Wright
    September 12, 2018 at 1:19 am
    this should work for the latest premiere:
    Mac: /Library/Application Support/Adobe/Common/LUTs
    /Creative
    /Technical
    Win: \Program Files\Adobe\Common\LUTs
    \Creative
    \Technical
  • Jeff Arthur
    September 12, 2018 at 4:15 am
    Thanks all. Youtube University helped out again!!! Long story short- you have to make sure your LUTs are copied into Media Encoder too- assuming you export from there!
  • Tim Taylor
    September 14, 2018 at 4:38 pm
    God bless YouTube U! Thanks for posting the answer. Id have never thought of that.
    Tim Taylor, Producer/Editor
    RESolution Media Services, LLC
  • Jeff Arthur
    September 14, 2018 at 9:51 pm
    Here is the video in case anyone runs into this issue.
    https://www.youtube.com/watch?v=yskE8bId72M
