Activity Forums DaVinci Resolve Color grade HDR and export as SDR
  • Color grade HDR and export as SDR
    Posted by Max Hoffmann on June 1, 2021 at 8:11 pm
    Dear All,
    I have a bunch of HDR recorded video from an Iphone 12 pro and like to export it as SDR with full grade applied. I am using no HDR monitors.
    Timeline Color Space: Rec 2100 ST2084 as well on Output Color Space.
    I enabled in Davinci Dolby vision in the color tab: Target Display Output: 100-nit, BT, 709, BT.1886, Full. I press ‘Analyze” and get a beautiful automatic image interpretation. Enabled is the Tone Mapping Preview.
    If I export the clip then it flat again.
    What Output Color Space do I need to select to get a SDR image?
    I appreciate all your help. Cheers
    Max Hoffmann replied 5 years, 2 months ago 2 Members · 2 Replies
  • Tom Watson
    June 2, 2021 at 12:54 am
    In my experience you should to set your Output color space to Rec.709-A for best results with iPhone footage.
  • Max Hoffmann
    June 2, 2021 at 3:12 am
    Thank you Tom. It works!
