Activity Forums Apple Final Cut Pro Color Finesse for FCPX?
  • Color Finesse for FCPX?
    Posted by Mark Arenz on April 2, 2015 at 7:49 pm
    I’ve been a long-time fan of Color Finesse 3 in After Effects. As far as I can tell, there’s no port for FCPX.
    All I want is a curves editor a highlight, gamma and shadow pickers for R,G, and B curves. That way I can fix bad white balance quickly and with better results than I can with stock FCP color or with many of the FXFactory plugins I’ve been trying. The Nattress curves plugin looks good, but the curves are not as editable as they would appear, so even if I just try to copy a curve that works for one of my channels, you can only get 75% of the way there (no x adjustment on curve points- which is probably the fault of FCPX’s limitations for the effects inspector UI).
    Have you folks found anything that works as well as Color Finesse for this kind of thing? Are all plugins for FCPX this limited in their UI?
    Brett Sherman replied 11 years, 5 months ago 4 Members · 3 Replies
  • Noah Kadner
    April 2, 2015 at 9:20 pm
  • John Davidson
    April 3, 2015 at 12:59 am
    And colorista III.
    https://prolost.com/blog/coloristafxpx
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Brett Sherman
    April 3, 2015 at 2:54 pm
    I used to use Color Finesse 3 for virtually all my edits in FCP 7. And missed it greatly once I moved to FCP X. Of course, it was never bug-free as a FCP plug-in.
    I passed on Nattress Curves, as it’s really NOT a curves plug-in. More of a highlight, mid, shadows adjustment. I also find the “Curves” section of Colorista not flexible enough.
    I think the closest you’ll get right now is Color Finale. It is quite good, if a little bit buggy at the moment. It doesn’t have color pickers, which would be nice. I combine it with Dashwood’s White Balance plug-in for FXFactory which I find is the best at correcting white balance with Kelvin adjustments.
