Activity Forums Adobe Photoshop Color Export Problems
  • Color Export Problems
    Posted by Pasteithere on December 28, 2005 at 7:37 pm
    I am having a problem with color in photoshop. I have been using Photoshop for years, but have never had this problem (I just switched to a Mac(.
    I will have a .psd that has the color just the way I want it. I export using ‘save as for web’ with a quality of 12.
    If I now open up the .jpg in photoshop and compare the two images, there is a difference in the color quality. The blues and greens are much duller, and the details are not as crisp as in the .psd.
    I have tested exporting with the ‘save as’ and using the .png, with the same results.
    Any suggestions with how to handle color?
    Pasteithere replied 20 years, 8 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    December 28, 2005 at 9:49 pm
    The Save for Web function in Photoshop does not attach a color profile to the file (normal Save As functions do it by default, though this adds to the file size a little). This means that when you re-open it, Photoshop doesn’t have a “guide” to use to define how the colors should be displayed. The end result can be a slightly different color appearance, depending on what color settings you’re using.
    Color Management is a wild and wooly topic. A good guide is Real World Color Management by Bruce Fraser and a couple of his buddies. The how, why, and where of CM seem a little intimidating at the beginning, but once you get past the basic concepts it’s all cake.
  • Pasteithere
    December 28, 2005 at 11:58 pm
    Thanks so much, I will pick up the book this week.
    At first I thought the problem was with Photoshop, and I might need to download an update, but it sounds like it is just knowing how to manage color is the main problem.
    Thanks again.
