Activity Forums Adobe After Effects Color Effects Only Applying to Some Frames
  • Color Effects Only Applying to Some Frames
    Posted by Suzann Johns on March 31, 2020 at 2:49 am
    So, I’ve finished masking, rotoscoping, refining matte, and I only need to do a bit of color touchup.
    The whole recorded scene/clip has a ghastly blue hue, so I tweaked and perfected my color corrections, using Auto Color, Auto Level, and Brightness/Contrast. However, when I scub through or simply play it outright, it looks as though the effects are on some weird techno pulse timing, becaus it’s only applying to approx. 5 frames, not applying to approx. 3, then applying to approx. 4 frames, not to 6, etc. It’s seriously infuriatinng!
    I’ve tried restarting the program, restartng the entire project, but I still get this pschedelic nonsense.
    What am I doing wrong & how do I fix it??
    Darby Edelen replied 6 years, 5 months ago 3 Members · 2 Replies
  • Richard Garabedain
    April 1, 2020 at 9:15 pm
    Re-read your explanation……I guess you just did not realize that AUTO levels and AUTO anything tries to adjust every single frame…change to the standard levels and such and there you go
  • Darby Edelen
    April 3, 2020 at 3:45 am
    First I’d recommend purging your disk cache, just in case there are some frames hanging around in there. Edit > Purge > All Memory & Disk Cache.
    You could try using the Temporal Smoothing feature of the Auto Color and Auto Levels effect in case what you’re seeing is the result of changing color levels in the source footage. Unfortunately, that tends to slow the effect down significantly.
    If changing color levels in the source is the problem then I’d suggest going with the other suggested solution of using the (non-auto) Levels effect.
    Darby Edelen
