Activity › Forums › Adobe Premiere Pro › Color different on HDTV than when editing in Premiere…what gives?
  • Color different on HDTV than when editing in Premiere…what gives?
    Posted by Jake Huddleston on September 7, 2011 at 10:55 pm
    I am working on a wedding DVD edited in Premiere Pro CS4 and burned with Encore. I had to do some color correcting to the footage (mainly to reduce the orange glow from tungsten lights) in Premiere. However, the final DVD, though it looks fine on my laptop, looks as if no color correction was done when played on a DVD player connected to my HDTV. Is there any way to color correct and ensure that it doesn’t look like crap when played back on someone else’s TV?
    I’ve been scouring a few threads and the general consensus seems to be that every playback device will show colors differently, but in my case it’s just so extreme. Any tips on how to solve this problem (or at least, make it better) would be much appreciated. Thanks!
    Jake Huddleston
    Walter Soyka replied 14 years, 11 months ago 6 Members · 9 Replies
  • 9 Replies
  • Tom Daigon
    September 7, 2011 at 11:22 pm
    In order to do any reliable color correction you really need to monitor the HD-SDI output on a professional external monitor. Using your computer screen will never allow you to see what the true nature of the color is. Any other way is just a crap shoot unfortunately.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digita / Areca 8tb. raid
  • Gary Huff
    September 8, 2011 at 6:13 pm
    [Tom Daigon]In order to do any reliable color correction you really need to monitor the HD-SDI output on a professional external monitor. Using your computer screen will never allow you to see what the true nature of the color is. Any other way is just a crap shoot unfortunately.
    Tom, I agree with you 100%, but do you have any suggestions for those who aren’t currently in the market (i.e. not enough money) for an SDI output card and monitor? Are there any suggestions for a cheap-ish (around $500 or so) monitor or ways to calibrate an already existing computer display to get somewhat close?
  • Tom Daigon
    September 8, 2011 at 7:36 pm
    Unfortunately,none that I am aware of. Sorry.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
  • Cody Walters
    September 8, 2011 at 9:04 pm
    Gary,
    In the past I’ve been recommended the Matrox mini or Matrox MXO2. The mini sells for $500. You would use this as your I/O and hook up a professional monitor for accurate monitoring of your coloring. I’ve read that others will just use an Plasma HDTV for there monitor while hooked up via an I/O device. Hope this helps.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Walter Soyka
    September 8, 2011 at 9:21 pm
    [Gary Huff] “Are there any suggestions for a cheap-ish (around $500 or so) monitor or ways to calibrate an already existing computer display to get somewhat close?”
    Premiere Pro isn’t color-managed, so it’s very hard to trust your computer display. If you’d like to see them add color management, please join me in filing a feature request [link].
    After Effects is color-managed, so if you have a decent monitor and calibrator to profile it (like you’d use for print), you should be able to get reasonably close.
    When in doubt, though, I still trust my HD-SDI monitor.
    Walter Soyka
  • Jeff Brown
    September 9, 2011 at 2:03 pm
    Yet another vote: you need an external monitor. AND, you need to learn how to set it up properly referenced to color bars. If you can’t afford a professional production monitor, even a small mass-market TV monitor will be better than your computer screen, IF properly set up to color bars.
    This may help:https://www.videouniversity.com/articles/color-bars-and-how-to-use-em
    -Jeff
  • Walter Soyka
    September 9, 2011 at 6:20 pm
    Color bars help you line up brightness, contrast, hue, and saturation, but they will not actually ensure the colors shown by your monitor are absolutely correct, nor will they help you ensure that brightness and gamma are correct.
    Color bars are better than nothing, but they’re not a substitute for a calibration engineer’s probe.
    Walter Soyka
  • Jeff Brown
    September 11, 2011 at 4:29 pm
    [Walter Soyka] “Color bars are better than nothing, but they’re not a substitute for a calibration engineer’s probe.”
    Agreed. But they do get you a lot closer than “I guess that looks OK.”
    Or using monitor “presets.”
    -jeff
  • Walter Soyka
    October 1, 2011 at 4:46 am
    For anyone interested in a technical description of the lack of modern relevance of blue-only color bar adjustments, see Joseph Owen’s great post here:
    https://forums.creativecow.net/readpost/223/22392
    Walter Soyka
