Activity › Forums › Adobe After Effects › color difference when i render to .mv2
Posted by Frank Van mourik on June 15, 2005 at 10:24 amihave huge color difference when i render my movie to .mv2? what is the problem. My movie looks just fine in AE but when i render it it looks totally differend?
please help
frank
Frank Van mourik replied 21 years, 3 months ago 3 Members · 9 Replies -
Mylenium
June 15, 2005 at 12:05 pmYour’colors are out of range i.e. not broadcast save? MPEG-2 (DVD) expects certain levels, otherwise the algorithm will go boom and screw your colors.
Mylenium
[Pour Myl
Aharon Rabinowitz
June 15, 2005 at 12:22 pmHere’s a trick I’ve used successfully in controling safe colors, which may help here…
For every piece of footage you bring in apply the Levels effect and set the following:
In Black: 16
In White: 235On another adjustment layer on top of your final comp use the same effect with the following settings:
Out Black: 16
Out White: 235Now I suspect that you could just make one final layer with 1 levels effect with all 4 settings, but I am not sure about the order of theeffect properties, so I don’t know if it’s a good idea.
The point of using this is to get rid of hot colors – you will see a difference on the computer screen- things get a bit duller, but you will barely see a difference on the TV, and the untrained eye will not notice a thing.
Plus in your case, where the algorythm is dealing with too many hot colors, this may correct for your problem.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Frank Van mourik
June 15, 2005 at 12:41 pmtnx looks like that wil do the trick but i’m working in AE 6.5 and that uses procentage and no absolute values! do you have the setting for that?
thanks a lot allready!
frank
Aharon Rabinowitz
June 15, 2005 at 1:56 pmThat is being caused by your info palette color settings. Go to the info palette, and click on the little black arrow (Points to the right)- all the way to the upper right corner.
You’ll get a pulldown with color display options.
Change the color setting from “Percent” to “Auto Color Display” – Now your colors will all be represented as units of RGB vs % of RGB.
I switched back and forth between the 2 and it looks like
16 = 6.2744%
235 = 92.157%—————————————-
Aharon Rabinowitz
Frank Van mourik
June 15, 2005 at 2:34 pmthnx i did what you said but everything still comes out quite ‘red’. i don’t understand it!
Frank Van mourik
June 15, 2005 at 2:54 pmis the MAGIC BULLET SUITE plugin from red giant a solution you think?
Aharon Rabinowitz
June 15, 2005 at 2:58 pmI get that a lot with quicktime with sorenson compression. You can try using the same effect (Levels) and adjust the levels on the red channel to desaturate it.
Also, you can try using the Color Balance Effect to lower the red on 3 seperate levels.
Finally, it bares mentioning that if you atre going to DVD, the codecs used to go to DVD look really cruddy on a computer monitor, but a lot better on a TV screen.
If you are going to DVD, why not try playing this on a DVD player and seeing if it looks better.
Aharon Rabinowitz
Frank Van mourik
June 15, 2005 at 4:08 pmThat realy makes a lot of difference! I used a tv screen and it stil wassend perfect but it was a lot better than viewing on my moniter!
think i’m also going to try the magic bullet suite plugin and see what that does! But still thank for all your help!bye Frank
