Activity › Forums › Adobe Premiere Pro › Color difference source monitor and program monitor
  • Color difference source monitor and program monitor
    Posted by Bella Gavelin on November 14, 2017 at 10:41 am
    Hi everyone,
    I am in a bit of a hurry here so have not started troubleshooting that long ago. Does anyone have a quick answer for this? I want it to look like in the source monitor. What setting is wrong and where?
    bella
    Todd Perchert replied 8 years, 10 months ago 4 Members · 5 Replies
  • Tero Ahlfors
    November 14, 2017 at 10:55 am
    Computer specs? Footage specs? Sequence settings? Are you using software or GPU rendering? Any effects on clips and/or adjustment layers?
  • Bella Gavelin
    November 14, 2017 at 1:01 pm
    Mac Pro 2013
    3 GHz 8-Core Intel Xeon E5
    64 GB 1866 MHz DDR3
    AMD FirePro D500 3072 MB
    Sierra 10.12.6
    Adobe Premiere Pro CC 2017
    Apple pro res mov files.
    No adjustment layers or effects. The files are graded and coming from a Davinci export. Looks correct in the source monitor.
    Sequence settings : Editing mode: arri cinema.
    GPU rendering.
    bella
  • Tero Ahlfors
    November 14, 2017 at 2:06 pm
    What you could try:
    -Turn off the GPU rendering
    -Make a new sequence with custom settings
    -Make a new project
    -Trash your preferences
  • Chris Wright
    November 14, 2017 at 3:01 pm
    Check your Master Clip Effects.
  • Todd Perchert
    November 14, 2017 at 8:56 pm
    So if you take your source footage in the bin, drag it to new item (lower right corner of bin), the program window opens looking that much brighter?
    TC
