Activity Forums Adobe Premiere Pro Color Corrections in a Multi Camera Edit
  • Color Corrections in a Multi Camera Edit
    Posted by Tod Geddes on March 10, 2016 at 7:22 pm
    Having a problem trying to do a multi-camera edit in Premiere Pro (latest). I import the footage from two cameras, one is dead on, the other needs to be tweeked. I switch screens to color and make the adjustments then go back to the edit screen. So far so good.
    Now I grab the footage and create a multi-camera source sequence, then a new sequence from clip…. except my color adjustments to the one are no longer there
    What did I miss??
    Thanks for the assist
    Tod Geddes replied 10 years, 5 months ago 2 Members · 2 Replies
  • Mark Whittle
    March 14, 2016 at 6:38 am
    Here’s how I do it:
    Select the clips you want to be in your multicam. Right click, choose Create Multicam Source sequence, Choose sync method and name it “Multicam SOURCE”
    I now have a sequence in my project window which I move into my sequences bin.
    This next bit is very important. Right click this multicam source sequence and select “Open in Timeline”. This lets me see the source clips all synched up and I manipulate the audio, do colour correction, add more clips (i.e. spanned clips), re-arrange the audio track order etc.
    When I’m happy, right click the source sequence in the project window and select “New sequence from clip” and a multicam sequence is created ready for live switching. At this point I rename this new sequence, removing “SOURCE” so I can tell apart the source sequence from the multicam sequence.
    At any time the source sequence is available if the audio needs mixing, or a shot needs adjusting somehow.
    I hope that helps.
    Mark W.
  • Tod Geddes
    March 14, 2016 at 4:46 pm
    Mark
    Thank for your assistance… worked great!!
    Tod
