Activity Forums Apple Final Cut Pro Legacy Color Correction+Film Effect=Serious Issues
  • Color Correction+Film Effect=Serious Issues
    Posted by Neal Carter on December 29, 2008 at 6:16 pm
    I just finished production on a 30 minute program shot and edited in HDV. One of my segments was shot in a dark pub, so I used color correction to lighten up several of the shots. At the end of the edit I applied a Nattress film effect to the entire project (Effect Preset=Nattress Basic 24fps). After the render I reviewed my work and thought I saw several black frames during the segment I color corrected. When I went through the troublesome areas frame by frame, I noticed that there were no black frames, rather the color correction effect I used to brighten some of the clips turned-off/vanished/did-not-apply during the last frame of the color corrected clip. It seems as though the color correction and film effect do not want to play nice together. Has anyone encountered this before?
    N Carter
    Editor || Videographer
    Rafael Amador replied 17 years, 9 months ago 4 Members · 4 Replies
  • James Disch
    December 29, 2008 at 6:41 pm
    Hey Neal, I’ve run into the same problem before. You need to make sure you Film effect is the first effect applied to your clip. You can apply any other filters after the film effect has been applied.
    James
    http://www.rapidlightproductions.com
  • Chris Poisson
    December 29, 2008 at 7:30 pm
    Film Effects have a host of color correction tools to play with. When I use them I rarely use any other color correction. But first off, editing in HDV is a no-no. You should at the very least change your compressor and render.
    Have a wonderful day.
  • Neal Carter
    December 29, 2008 at 7:43 pm
    I will experiment more with the film effects color settings, but I do enjoy the ease of use within FCPs Color Correction. As for HDV, our show is delivered for broadcast on an HDV tape (stations requirements) so that it can be broadcast in HD. I am always willing to try a new workflow, but is there another suitable workflow if we are shooting in HDV and must deliver the final on an HDV tape?
    N Carter
  • Rafael Amador
    December 30, 2008 at 5:44 am
    [Neal Carter] ” but is there another suitable workflow if we are shooting in HDV and must deliver the final on an HDV tape? “
    No.
    But is a pity that almost all the improvement you can get through CC/Chroma Smoothing will desapear when rendering back to HDV.
    Rafael
    http://www.nagavideo.com
