Activity Forums Adobe After Effects Color Correction? Need some help…
  • Color Correction? Need some help…
    Posted by Austin Ray on February 13, 2006 at 10:47 pm
    I need some help with Color Correction. I have a film shot with Sony PD150 on DVCAM.
    Its shot outside in the snow, and I need to do something with it to make it more alive.
    https://www.rabbefilm.no/temp/NAKTA-01FP1.pdf
    This link leads to a PDF-document showing 10 frames from the movie. First frame is with my filter (only a spotlight though) and then the same frame as an original.
    If any one have some time and could give me some tips on what I should do here, I would be more than glad.
    Thanks.
    Chris Smith replied 20 years, 7 months ago 3 Members · 3 Replies
  • J
    February 13, 2006 at 11:14 pm
  • J
    February 13, 2006 at 11:37 pm
    Also, be ready for long render times. I did color correction in After Effects for a film I worked on. The render times were about an hour per minute. Make sure you break your renders up be scenes! The files are large.
    If you want to see the final results, here they are:
    33mb
    https://www.skeletonpix.com/Ropes_H264_320_15fps_02.zip
    60 mb
    https://www.skeletonpix.com/Ropes_H264_640_29.97_04.zip
  • Chris Smith
    February 14, 2006 at 5:05 am
    Well, you will want to isolate areas of each shot to color separately and then color the image as a whole.
    For isolating areas:
    Remove your spotlight. Duplicate your footage. On the duplicate, use a mask to isolate an area you want to change (like maybe add more “light” on the key person. Or maybe you want to darken the sky. Put a matte around the are want, then feather the matte a LOT. Now add your favorite color correction method here (like CF, or curves or a levels and hue/sat) Adjust them and you will see the area you isolated start to change. Be subtle because tweaking areas to extreme can become fake quickly.
    Now add an adjustment layer over the two layers. Now color correct both layers together. First of all it looks like your balcks aren’t touching blacks. Use levels to bring in the blacks till they are are at RGB 0. Then move your gamma to the right to darken the image a bit. This will give a nice richer tone to the image.
    Chris Smith
    https://www.sugarfilmproduction.com
