Activity Forums Adobe After Effects color correction with different videos
  • color correction with different videos
    Posted by Simmizi on March 23, 2006 at 8:26 pm
    hello!
    a few days ago i’ve tested my new camera…i’ve got some pretty nice shots so i decided to make them look a little bit better.
    here is what i’ve got:
    before:
    home.arcor.de/becker.fam/colorcorrectionbefore.avi
    after:
    home.arcor.de/becker.fam/colorcorrection.avi
    (both videos are compressed with the divx-codec)
    now i have a problem: the color correction works only with my snow-videos (because they have a lot of blue)….but if i want to do the color correction effect at other videos it doesn’t look the same….it hasn’t the same look.
    my question is…what can i do to reach the same “look” for different videos (different light-conditions and so on)…
    thanks
    simmizi
    Steve Freebairn replied 20 years, 5 months ago 4 Members · 5 Replies
  • Steve Freebairn
    March 23, 2006 at 9:11 pm
    Color correction can help, but the real problem here is that you shot Daylight (outdoor 5600 K light) with your camera set on the Tungsten (indoor 3200 K light) setting. If you switch your white balance for either daylight or tungsten you won’t have either really blue or really orange looking images.
  • Chris Smith
    March 23, 2006 at 10:55 pm
    Like the guys said, learn to shoot correctly balanced first, then it’s easier to achieve a “look” in color correction from shot to shot. So you’re not making up for where the camera was setup unbalanced.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Solie Swan
    March 24, 2006 at 2:52 am
    Make sure that in both clips you use the plugins white adjustments to something you know is white in both shots – that should get you close. If you have a 3way color correcting plugin then do the same to areas in both clips that you know are supposed to be black.
  • Simmizi
    March 24, 2006 at 8:21 am
    i know this is a bad example and i didn’t use the white balance…but i chose it to schow you what i mean…and i just wanted to know if this is possible or not…i’ve already thought about a plugin which changes the white of the second video into a the white of the first video…(and the other colors) but i don’t know what plugin i should take…
    thx
    simmizi
  • Steve Freebairn
    March 24, 2006 at 7:10 pm
    Your colors will match very well if you white balance your shots. You should be doing as much in production to avoid having to fix it in post-production. If you white balance under various light sources, someone’s blue shirt is going to be the same hue of blue no matter where you film them.
