Activity › Forums › Apple Final Cut Pro Legacy › Color correction, suggestions please!
  • Color correction, suggestions please!
    Posted by Anthony Faulkner on May 25, 2010 at 2:04 am
    I shot a live show recently, I didnt get a chance to set the white balance correctly before it started, and there was a variety of lighting and it was underlit.
    I bumped the gain and used 4300 setting on an EX3.
    the result is a slightly dark and yellow image.
    I have tried messing around with correcting it.
    I haven’t made much headway in sparking the image up.
    If anyone can give me any suggestions for methods to improve the image i would be grateful.
    thanks
    Anthony
    Stephen Smith replied 16 years, 4 months ago 4 Members · 6 Replies
  • Michael Sacci
    May 25, 2010 at 4:12 am
    You can post a still are two and you may get more help but you are in deep trouble. That is a bad combo of issues, Bad white balance, underexposed and you used the gain in the camera. It ain’t going to be pretty.
  • Anthony Faulkner
    May 25, 2010 at 4:15 am
    There is an attachment of a small clip that i have attempted to fix.
    click that grey triangle in the post..
    thanks
    Anthony
  • John Pale
    May 25, 2010 at 4:39 am
    I don’t see any grey triangle, and apparently neither does Michael.
  • Anthony Faulkner
    May 25, 2010 at 4:56 am
    that is bizarre, because I just checked on a different computer and there is a clip on the bottom of the message????
    maybe ill try and upload it again?
  • Anthony Faulkner
    May 25, 2010 at 5:05 am
  • Stephen Smith
    May 25, 2010 at 2:38 pm
    I’m assuming the curtains are black or close to it. Apply the 3-way color corrector and select the blacks eyedropper. Select the curtains and that should get rid of the yellow tint. Best of luck.
    Utah Video Productions
    Check out my Motion Tutorials
