Activity Forums Adobe Premiere Pro color correction render on ppro2 3x slower than ppro1.5
  • color correction render on ppro2 3x slower than ppro1.5
    Posted by Bernardo on May 26, 2006 at 1:59 pm
    Hi guys.
    I did download the ppro2.0 tryout a couple of weeks ago and i’m running some tests.
    Working with Ppro2.0, the same shot with the same color correction effect takes at least 3x more time to render than ppro1.5.
    Plus, when working with rgb curves(and other color corrction fx) it takes like 1 second to update. the working process had a huge slowdown in performance, with ppro2.
    it’s that right?
    I did the same questions a few weeks ago and nobody answer me…
    thanks in advance.
    Bernardo
    Bernie replied 20 years, 3 months ago 3 Members · 2 Replies
  • Troy Murison
    May 26, 2006 at 7:54 pm
    I have noticed the same. Thought maybe it was just my imagination.
    So I just did a test with similar much slower results vs. 1.5 render
    using Three Way Color Corrector effect. Can this be right?
    I have also noticed rendering stills is slower as well (not to the
    extent that CC is slow though) but I have not done a true test,
    so that may well be my imagination.
    -Troy Murison
    Seattle, WA
  • Bernie
    May 26, 2006 at 10:26 pm
    Yep, I have been running many performance comparision tests, and ppro2 it’s at least 3x slower….
    Unfortunally, because i thing ppro 2 more stable than ppro 1.5
    Any thoughts?
