Activity › Forums › Apple Final Cut Pro Legacy › Color Correction: Plug-in for applying CURVES and LEVELS in final cut?
Posted by Flyfilmsposter on December 13, 2006 at 1:25 pmanyone know of a plug-in for FCP (I don’t believe there is an existing function) that allows you to either (a) design and apply curves possibly even in individual RGB channels as an effect to video elements or (b) similar but with a histogram and level function, both which are standard and two most popular photographic color correction techniques on still images. The 3 way color wheel is a very simple approximation of a a process that can be more delicately and intuitively (i guess for those who are used to Curves) rendered.
Thanks in advance.
-AlexJacob Wade replied 18 years ago 7 Members · 8 Replies -
Walter Biscardi
December 13, 2006 at 1:27 pmThere is a Levels Filter in FCP which I use as part of Color Correction.
Sythetic Aperture has a nice plug-in for FCP that I believe you can try for free.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Arnie Schlissel
December 13, 2006 at 2:05 pmI think Graeme Nattress may also make a plug in for this. nattress.com
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Flyfilmsposter
December 13, 2006 at 2:29 pmthanks guys. we’ve tried both these plug-ins. both of them and the fcp have actions called CURVES or LEVELS but they all are simplified attempts with single or a few sliders as opposed to the ability to design and apply user-specified curves matching the specific needs to adjust data in the histogram, video tonal info and look and feel on the screen. if anyone is familiar with how curves and levels are used in photoshop (on still images).
the way the function works in photoshop (for example) is a histogram is viewed (like in viewscopes which does exist in fcp) and either a blank curve or a histogram with range handle is presented by the plug-in and the user can manipulate directly either the shape of the curve (in a pen tool way – think keyframes) or the in-out-inflexion of the levels precisely to adjust. Once you get the hang of it it is way more intuitive and powerful and simple that the flat single/multiple slider solution which butchers and crushes blacks and highlights with little discretion.
if anyone develops for fcp and has an interest is putting this together contact me for sure. be well. thanks.
Glenn Chan
December 13, 2006 at 4:28 pmHmm not even Final Touch does that (curves/smoothstep interface is limited like in FCP; the other curves do something else).
Color Finesse and After Effects both have curves like what you describe. After Effects is very photoshop-like in that many photoshop filters and features can be found in AE.
Chris Poisson
December 13, 2006 at 11:19 pmColor Finesse is available for FCP, it has what you want.
Alan Okey
December 14, 2006 at 6:19 amI believe that Conduit, the new node-based compositing plugin for Final Cut Pro, has a curves node that may function in the way that you need.
https://www.dvgarage.com/prod/prod.php?prod=conduit15
Check out the video clips for reference, I seem to recall a section addressing the curves function.
Walter Biscardi
December 14, 2006 at 11:54 am[flyfilmsposter] “if anyone develops for fcp and has an interest is putting this together contact me for sure. be well. thanks.”
The tool you really want to use is Final Touch HD which Apple has just purchased from Silicon Color. BUT, it works so badly at this point that we have put it on the shelf and are waiting to see how Apple addresses all the issues with the software at NAB. Only beta copies are available of it at the moment as Apple has halted all sales.
Short of that Color Finesse from Sythetic Aperature is the best CC tool out there for FCP. It doea have a histogram and curves.
Jacob Wade
September 6, 2008 at 4:58 amIf you choose the Color Corrector filter, you can drag the bars of Blacks, Whites, and Midtones to estimate the level changes. That is what I use and it works pretty well.
