Activity Forums Apple Final Cut Pro Legacy color correction on white background
  • color correction on white background
    Posted by Dave Martin on December 3, 2008 at 11:26 pm
    Hi Guys
    I have a bunch of people shots which are on a white background (they were shot on a studio cyc). The lighting was pretty good but not perfect. Client wants the white to be whiter but not affect the people in the foreground.
    Is it possible with the tools in FCP to bring up the white background but not mess with anything else in the shot? Sure appreciate it…
    Dave
    Dave Martin
    – MacPro – MacBook Pro –
    Dave Martin replied 17 years, 8 months ago 4 Members · 6 Replies
  • Chris Borjis
    December 3, 2008 at 11:40 pm
    scroll down to the section on “secondary color correction”
    https://www.kenstone.net/fcp_homepage/cc_legal_fcp4.html
  • David Battistella
    December 3, 2008 at 11:45 pm
    Why not start by using the eydropper for the whites on the white part of the frame.
    David
    Peace and Love 🙂
    Read my Blog
    https://blogs.creativecow.net/DavidBattistella
  • Gary Hughes
    December 4, 2008 at 3:27 am
    First off, if your white is a little saturated, you can fix that easily with the 3-way CC. Reply if you need to know how.
    Secondly, if your footage is close, here’s something to try. You can do this with either 3-way or 1-way CC. Take the slider for highlights (whites) and push it up till you have acceptable white in your BG. Then take the slider for mids and slide it down till the people are acceptable. It may take a little tweaking, but if you are close to begin with, this may work. It won’t ignore the people completely, but you may just find a happy medium. If you go too high with the whites, just throw the broadcast safe filter on top.
    Hope this helps,
    Gary
  • Dave Martin
    December 4, 2008 at 12:14 pm
    Thanks All!
    All great suggestions. Since I have 300 clips I’ll probably use the 3 way CC. There is a little saturation in the white…Gary – could you share how to knock that out as referenced in your answer?
    Thanks again guys!
    Dave Martin
  • Gary Hughes
    December 4, 2008 at 3:17 pm
    Dave,
    There are a few ways to reduce the saturation in the whites. You can use a Desaturate Highlights filter, and I’ve done that. That works if you have more than one color in the highlights, like a blueish hue in the top left and a warmer hue in the top right because of light coming in through a window on a scene lit with tungsten. However, if you don’t have multiple hues in your highlights, and especially since you are using the 3 Way CC anyway, I would just try to use it to neutralize or white balance the whites.
    To do it by sight (or scopes), just drag the white dot in the center of the whites color wheel toward the opposite color of the hue in your shot till it’s right.
    To do it automatically, just click the eyedropper beneath the whites color wheel and click on something that should be white in the scene in the canvas.
    Here’s a great tutorial for more advanced hue matching using 3 way CC. https://www.kenstone.net/fcp_homepage/match_hue_fcp_5_balis.html
    Have fun,
    Gary
    Gary
  • Dave Martin
    December 5, 2008 at 1:05 am
    Absolutely Splendid!!!!
    Thanks so much Gary…those were the tweaks that I needed…quick and simple!!!
    Sure appreciate it!
    Dave Martin
