Activity Forums Apple Final Cut Pro Legacy color correction on an apple 23″ cinema display
  • color correction on an apple 23″ cinema display
    Posted by David Garcia on June 29, 2005 at 1:31 am
    Hi.
    Not sure if this is the best place to ask this question, but I’m wondering if my apple 23″ cinema display can be used a reliable monitor for color correction.
    I know it’s not a video CRT, but When I purchased it I was under the impression it would work.
    If it is appropriate, what calibration if any do I have to do on it.
    Thanks for any input,
    David
    R. Hewitt replied 21 years, 3 months ago 7 Members · 6 Replies
  • Kevin Monahan
    June 29, 2005 at 1:37 am
    No, you need a CRT to do color correction with any accuracy. You can use a Black Magic HD Link hooked up to it to do the job though, from what I understand.
    As a stock monitor, no, you cannot trust it though.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Graeme Nattress
    June 29, 2005 at 1:47 am
    It’s not so much the monitor you can’t trust, but the fact that FCP mucks around so much with the image before it gets to the monitor. When you use the 23″ via the HDLink, FCP thinks it’s sending video to a deck over SDI, so the image goes the same route it would going to a “real”monitor, and the HDLink handles the gamma stuff properly, making the image look very accurate and much nicer than the monitor hooked direct to the computer.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Walter Biscardi
    June 29, 2005 at 11:57 am
    My favorite monitor for color correction is the Sony PVM20L5/1. They won’t be around much longer as all CRT’s are going away, but for price and performance, you can’t beat this monitor. Last I looked they were around $2,800.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Gary Adcock
    June 29, 2005 at 1:56 pm
    while the SDI to DVI-D converters and digital cinema desktop are great things to have EVEN apple say that you cannot do critical color correction on any apple display
    https://docs.info.apple.com/article.html?artnum=93797
    Although this setup works for any video format, it can be particularly useful when editing high definition video that would otherwise require a fairly expensive HD monitor. Progressive video formats such as 720p are well suited for monitoring on a computer display. If you are doing critical online editing or color correction, you may still want to use an external CRT video monitor, especially when your final output is interlaced broadcast video.
    gary adcock
    Studio37
    HD and Film Consultation
  • Mrvideo
    June 29, 2005 at 3:12 pm
    As it is , CRT monitors are not going to be used in HD televisions or projectors that can emit 1920×1280 images. If those projection systems are going to misrepresent the actual colors of the images, what then can we do to correct them CORRECTLY when the material will never touch a CRT?
    Panasonic is already selling a very expensive LCD based “production” monitor?
  • R. Hewitt
    June 29, 2005 at 4:23 pm
    Biggest problem right now is the difference in gamma between a CRT and and LCD panel. Take a look at any LCD TV and you’ll see crushed blacks (well dark blue – LCDs don’t do black) and burnt out highlights. Then you have the colour to deal with.
    Sony are producing ‘broadcast/professional’ grade LCD monitoring panels, which will eventually start to replace CRTs.
    Sony Europe. Checkout the Products/Broadcast & Professional/Production Monitors/LCD.
