Activity Forums Adobe Premiere Pro color correction of multiple clips
  • color correction of multiple clips
    Posted by Raine Parrish on February 12, 2006 at 9:50 pm
    hello,
    working on a sequence with multiple clips that need to be color corrected/balanced. is it possible to do this in premiere (6.5)? I also am using after effects (6.5) if that is a better choice for the job- but don’t know how to do it inAE either.
    thanks much in advance.
    rp
    Raine Parrish replied 20 years, 7 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    February 13, 2006 at 8:27 pm
    It’s not really possible in Premiere 6.5. You can copy and paste the effect from clip to clip if the settings will be the same.
    In AE, you can simply pre-compose all of your clips into a new comp, and apply the color correction to that nested comp. In Premiere Pro, you can do the same thing with nested sequences.
  • Raine Parrish
    February 13, 2006 at 8:43 pm
    thank you for reply. i’ll give it a try.
