Activity Forums Adobe After Effects Color Correction Mac Vs PC
  • Color Correction Mac Vs PC
    Posted by Laurie Turner on January 4, 2008 at 5:53 pm
    I have an After Effects Project that looks great on my IMac with Intel, and when I export it as a quicktime movie it still looks good. When my co-worker watches the quicktime on his PC, the color looks dull. This project will adventually go on the internet. Is there a rule of thumb when doing color correction to have it look good both on Mac and Pc?
    Paul Carlin replied 17 years, 7 months ago 3 Members · 3 Replies
  • I.a. B.
    January 4, 2008 at 9:58 pm
    are you watching it on the same screen?
  • Laurie Turner
    January 7, 2008 at 4:30 pm
    Good questions.
    no, I watched it on two Mac screens, looks great and I watched it on 4 PC screens, it looks dull.
  • Paul Carlin
    January 12, 2009 at 2:12 am
    Short answer:
    Mac is historicaly 1.8 Gamma and PC’s are 2.2 Gamma. If you color correct at 1.8 and display at 2.2, it will be washed out gray and desaturated.
    You need to look at your workflow and make sure your color management is in order. Read up on the “Match Legacy After Effects QuickTime Gamma Adjustments” option in AE’s project settings. While you’re there, read up on color management as well.
    Also, QuickTime Animation codec is a disaster for managing gamma. Prior to version 7 it was one way, then another, then they decided to do this, then that…. AHHHHHH!! AE even has a
    Try converting it to it’s final destination codec (H.264?) and play that on both systems. See if you have the same problem.
    Although not completely relevant, this makes for good reading…
    Aperture: Color and gamma settings for print and web
