Activity › Forums › Apple Final Cut Pro Legacy › Color Correction in FCP
  • Color Correction in FCP
    Posted by Jimy Bleu on November 6, 2006 at 6:13 pm
    How do I access the “Y” waveform in FCP5 (I’m not sure of the term in FCP, in Avid it’s called the “Y” waveform).
    I can somewhat do color correction in FCP w/out the waveform using the vector scope, but in Avid, the “Y” waveform seems more accurate since it shows the actual band length & width, which is why I’m trying to access it in FCP……
    Unless anyone can suggest a better process??
    Thanx
    Glenn Chan replied 19 years, 10 months ago 3 Members · 2 Replies
  • Andreas Karoliussen
    November 6, 2006 at 9:45 pm
    Im not that familiar with Avid,
    however Waveform monitor you can access through the menu: Tools and Waveform Scopes
    (or try hitting alt/option + 9)
    and in the Layout menu you choose your point of interest. If you choose “all” Y(luminance) is in your lower left;-)
    In addition Id recomend a video monitor as main reference.
    Good Luck!
    Andreas
  • Glenn Chan
    November 8, 2006 at 11:05 pm
    In FCP, you can switch the waveform monitor between its two different modes. There is a setting for either “luminance” or “saturation”. Luminance should correspond to Y mode, or “low pass” or “lpass” mode on a hardware waveform monitor. “Saturation” should correspond to a hardware waveform monitor with low pass turned off; it will show you the composite signal, a composite of both the luma (Y) and chroma.
    In older versions of FCP, there are some inaccuracies in the scopes.
    – They only sample every few lines; they don’t sample every pixel. In the latest version of FCP, FCP will sample every pixel when the video is not playing.
    – They clip superblacks (levels below black level). Not sure if this has been fixed (haven’t checked).
    – This doesn’t really relate to the scopes, but sometimes the broadcast colors filter won’t be applied when rendering. So the scopes may show legal levels, but the rendered video does not have legal levels.
