Activity Forums Adobe Premiere Pro Color correction for blownout highlights
  • Color correction for blownout highlights
    Posted by Tim Mccarthy on August 8, 2008 at 10:59 pm
    I have some footage that I shot of a talking head, basically (guy standing behind a table talking). Due to the quick nature of the shoot and equipment shortages, I wasn’t able to properly light the subject and was forced to use a lower-end prosumer camera (I bounced one light off the ceiling in a room with flourescents). I ended up with a decent picture, but with a blownout highlight area on the upper side a head with white hair and a receding hairline. Using PP2, what is the best way to bring down those highlights so they’re not so blownout looking without losing much of the rest of the brightness and color?
    Jon Barrie replied 18 years ago 3 Members · 2 Replies
  • Vince Becquiot
    August 8, 2008 at 11:16 pm
    Unfortunately, as you probably know, in digital, over means lost.
    It will almost always appear as white no matter what you do.
    You can use the levels filter to try to minimize the effect, but it may actually bring more attention to that area.
    In After Effects, you could track the area and use the stamp tool to cover it up, but unless you spend a lot of time touching up, it will probably not be convincing.
    Vince
  • Jon Barrie
    August 9, 2008 at 1:30 am
    I’ve been pleasantly surprised by the amount of detail one might assume is lost in the whites of video. Only when you see the vectorscopes will you see where they may be some embedded detail.
    Use the effect:
    “shadows highlights”
    Play with these settings and you may be able to find some detail in highlights without ruining the mid and blacks areas.
    You can pull out some more detail in the blacks with this effect too. Don’t use the auto settings (default) play with the parameters.
    – Jon Barrie 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
