Activity Forums Apple Final Cut Pro Legacy Color Correction & Flickering Problem
  • Color Correction & Flickering Problem
    Posted by Tim Glenn on September 2, 2008 at 10:20 pm
    Anyone having a problem with flickering after applying color correction in FCP? I am able to get the desired colors, but I often end up with flickering in the corrected areas. I have found that reducing the Edge Thin can help, but I really need to be able to use both correction and Edge Thin. I’ve tried also adding Flicker Filters and Broadcast Safe. I’m working in HDV with FCP 6.0.4. Any suggestions would be appreciated.
    TG
    Michael Gossen replied 18 years ago 3 Members · 4 Replies
  • Michael Gossen
    September 3, 2008 at 2:04 am
    What kind of project are you working on? Framerate, codec, etc? How are you monitoring? Describe the flickering. It sounds like you are talking about Secondary corrections (Limit Effect) if you are using ‘Edge Thin’, is this true?
    Michael Gossen
    Helium Digital Media
  • Tim Glenn
    September 3, 2008 at 3:11 pm
    Michael –
    Thanks for the response.
    When starting my session to capture, I used Easy Setup – HDV, 1080i60 Firewire Basic, 29.97fps. The footage was shot on a Canon XH-A1 in HD. The Sequence Settings are: 1440X1080 16X9, HD, Field Dominance Upper Odd, Compressor HDV 1080i60. I am using Limit Effect to specific colors in the frame. I am monitoring on an Apple Cinema HD set to 1600X1200 Stretched, Colors Millions, Color set to Cinema HD Display. The flickering is a nervous vibrating change from bright to dark, much like lightning. It is only occurring in the Limit Effect color areas. Timeline is set to Safe RT. Ideas?
    TG
  • Phil Holbrook
    September 4, 2008 at 4:16 pm
    Did you render after getting your colors corrected. That flicker is always there for me until I render the clips (a preview green line above the clips?).
    Phil
    Just like you remember it…
    maybe better.
  • Michael Gossen
    September 4, 2008 at 5:59 pm
    Aha! I know what you are talking about. You’re gonna need to work on your limit effect. I was going to write out a long explanation, but I think the manual does a good job, so check out page 603 in the FCP manual.
    Basically, keep working on your HSL selections. The eyedropper is only a place to start. Tip: You can add HSL values with the eyedropper by holding down ‘Shift’.
    Good luck.
    Michael Gossen
