Activity › Forums › Apple Final Cut Pro Legacy › Color Correction doesn’t apply
Posted by Ana Garcia on June 6, 2013 at 2:38 pmHi,
I was trying to color correct a project but the effects doesn’t apply to the image. Does anyone know what can be or how to fix it?
Thank youTom Gomez replied 13 years, 2 months ago 4 Members · 6 Replies -
Mark Suszko
June 6, 2013 at 4:22 pmDouble-click the clip to select it, then apply the color correction tools to it.
Mark Suszko
June 6, 2013 at 8:51 pmAre you dragging an icon onto the clip, or are you going to the top menu after highlightng, and selecting from the drop-downs:
EFFECTS> VIDEO FILTERS> COLOR CORRECTION> your choice?
Are you in FCP 7 or are you in X?
Ana Garcia
June 7, 2013 at 9:47 amI’m working in FCP 7 and I’ve tried both ways, dragging the icon into the clip and the top menu thing.
Whenever I try to intervene, and perform any command in the effect, it doesn’t apply. -
Rafael Amador
June 7, 2013 at 1:16 pmDouble click the clip on the time-line and click the “Effects” tab on the viewer.
Make your changes there.
rafael -
Tom Gomez
June 7, 2013 at 1:24 pmHey Rafael! Once upon a time someone made mention of two filters to be applied in FCP to make the project broadcast safe, since the Broadcast Safe filter doesn’t do the whole job. Was that you? 🙂 Do you happen to remember which filters they were and what the settings were?
THANKS!
-Tom
YOU can help save TimeSpace. Join the Chronos Protectorate!https://www.95ers.com
https://www.SpaceAceMedia.com
