Activity › Forums › Adobe Premiere Pro › Color Correction – Brightness
  • Color Correction – Brightness
    Posted by Anandabrata Ghosh on December 23, 2007 at 6:34 pm
    I have two clips, A and B. Lets say A has been shot in the afternoon and B has been shot during early evening.
    The brightness levels on the two clips are different. I want to make the brightness level of B just as that of A. How can I do that?
    Besides I have had a look at Color correction tutorial which only talks about the RGB tinge adjustment. Where can I get more information of all color correction techniques for PPCS3.
    Regards,
    Anand
    Anandabrata Ghosh replied 18 years, 9 months ago 2 Members · 2 Replies
  • Mike Velte
    December 24, 2007 at 12:08 pm
    Color correction and brightness adjustments are two different processes, although on occasion both are needed.
    Color correction assumes that there is an unnatural color cast to the image/frame. Things in the frame that should be a shade of gray (0,0,0 – 255,255,255) actually have some color. The color correction process fixes this.
    Brightness (luminance) adjustments is not so much a correction process as it is enhancement. The Levels and RGB curves effects are often used for this.
    My favorite place for tutorials is Lynda.com
    Chad Perkins has a “Beyond the Basics” training for Pro with a section on these subjects.
    Photoshop tutorials can also be helpful getting your head around the world of colors and luminance.
  • Anandabrata Ghosh
    December 26, 2007 at 3:40 am
    Hi Mike,
    Thanks for the inputs.
    Regards,
    Anand
