Activity › Forums › Apple Final Cut Pro Legacy › Color correction applied to multiple clips in the sequence at once
  • Color correction applied to multiple clips in the sequence at once
    Posted by Nick Patten on August 4, 2010 at 2:49 pm
    Hi
    I ve been editing 12 cameras for a concert using the multiclip (*which I must say is great, great, great). I finished the 2 hours concert and now I want to grade it.
    Each camera needs a slight adjustment. No need to go to Color itself but just use the RGB balance within FCP.
    So I balance the colors for each camera and drag the filter into a bin.
    At the moment what I do I navigate trough the timeline hold down apple and click on each clip belonging to a certain color correction filter until I select all the clips from that camera.
    But there must be an easier, faster way to grade.
    Any tips advice much appreciated.
    Thanks a lot
    Gordon Henry replied 10 years, 2 months ago 5 Members · 5 Replies
  • Rob Tinworth
    August 4, 2010 at 6:31 pm
    Apple-F in the timeline allows you to select every clip that is associated with each camera. This assumes that they are named uniquely to reflect which angle they are.
    Rob Tinworth
    http://www.1021.tv
  • Michael Gissing
    August 4, 2010 at 11:48 pm
    I would also recommend that you use the 3 Way CC filter instead of RGB balance. The 3 Way CC is a much better filter so learniing to use it will give you much better control over balance, white, black levels and gamma, all in the one filter.
  • Nick Patten
    August 5, 2010 at 6:34 am
    Hi
    Thank you very much all.
    Apple F a life saver. 🙂 Just typed in the name of that camera and all the clips with the same name were selected so I can paste attributes or remove at once.
    Many many thanks
  • Kamal Gad
    September 19, 2011 at 8:48 pm
    hello i need some sugesstion
    how can i use premiere proj file in after effects
    and i hav arranged all files in a sequence and exported it
    i got an output file how to make color correction on it it is combined of all files
  • Gordon Henry
    July 6, 2016 at 4:56 pm
    Hi dave,
    I am currently finishing off a multi clip edit which was shot on 2 cameras… one of the cameras looks quiet different in saturation and colour match .. how can I apply the grade to all the clips from the same camera on the multi clip timeline … the show is about 45 mins long .. yes I am very new to FCP 7 multiclip grading so excuse the fact i am sort of asking for step by step instructions 🙂
    can you please explain the procedures for doing a colour match grade .. also is it possible to apply the grade to only certain amount of the footage as I noticed the last 3rd of the act … ( it a kids theatre show.. ) the colour balance seems a lot better and evenly balanced between the 2 cameras… not sure if the operator switched camera white balance settings.
    As ever thanks in advance .. oh wise one
    DN
