Activity Forums Avid Media Composer Color correction and keyframes?
  • Color correction and keyframes?
    Posted by Matt Babinec on May 26, 2005 at 1:28 am
    hi,
    is it possible to keyframe color correction effects so i can have one part of a clip on one setting, and another later on in that same clip a diffrent setting?
    thanks!
    Matt Babinec replied 21 years, 4 months ago 2 Members · 2 Replies
  • Chris Bové
    May 26, 2005 at 1:39 pm
    Actually, I usually create an edit point at about where I want the color change to start, make the right side of the clip the new color and dissolve between the two. Reason: saves time. If you want to change the end color, you only have to render the right 1/2.
    3 color correctors I use:
    – Avid’s own “color effect”
    – Avid’s color correction interface
    – 3Prong’s plug-in (nice flexibility, rener time is a bit long, but worth it – you can create gradiant filter effects, etc).
    ______
    /-o-o-\
    \`(=)`/…Pixel Monkey
    `(___)
  • Matt Babinec
    May 26, 2005 at 9:01 pm
    ok, thanks for the tip! i will try it out tonight!
