Activity › Forums › Apple Final Cut Pro Legacy › Color correction and external monitor
  • Color correction and external monitor
    Posted by Francisco Bech gómez on October 25, 2009 at 12:00 pm
    Hello again, I want to correct colors with FC and external broadcast monitor. It is better to use an analog monitor or a Digital monitor. Apple sells a Mini DVI to Video adaptor with composite (RCA) and SVideo outputs, would this be enought to work with an analog monitor? or I need a canopus card to use conponent video, is this an important issue for the image in the monitor?
    Thanks very much for your help
    Michael Gissing replied 16 years, 11 months ago 3 Members · 3 Replies
  • Walter Biscardi
    October 25, 2009 at 12:18 pm
    Analog or digital are fine so long as you have a properly calibrated monitor and feeding it a good, professional signal.
    [francisco bech Gómez] “Apple sells a Mini DVI to Video adaptor with composite (RCA) and SVideo outputs, would this be enought to work with an analog monitor? “
    Composite is the worst possible choice for monitoring professional video. S-Video is the bare minimum so long as you have a properly calibrated external monitor.
    If you’re working in HD, then Component is the bare minimum you will require.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Francisco Bech gómez
    October 25, 2009 at 6:35 pm
    Hello, thanks very much for your help
    I am working in DVCpro 50 in Imac. Could you tell me please how can I get the signal to a monitor? I guess the only output is the Mini DVI . I been researching and I cant find a clear answer for this
    It would be digital or analog?
    Best regards
  • Michael Gissing
    October 25, 2009 at 9:02 pm
    Look at the AJA IO .
